CHEVROLET Camaro - 1000 HP aka Che-Guevara
Привезли ось таку систему вихлопа коллетори EDELBROCK та CatBack MAGNAFLOW
на автомобіль CHEVY CAMARO Z28 5.7 V8 1993 року.
Будемо встановлювати - будуть фото.
Комплект шестипелюсткового карбон-керамічного щеплення
Автомобіль - Chevy Camaro LT1 (5.7L) 4L60E 93-97
Виробник - EZ Clutch
Part # - EZ3-82040
Сapabiliti - Up to 600 HorsePower
ціна в Україні - 848$
Комплект шестипелюсткового кевлар-керамічного щеплення
Виробник - MadorRacing
STAGE 3 - Street Strip Stage 3+ Kevlar Series 2400 Clutch Kit for LT-1 Chevy for T-56 tranny
The CC Strip 2400 series kit is the ultimate road and track performance kit. This assembly allows for ease of gear transition and smoother take off. Strip Series 2400 is designed for street or track use for vehicles with a 150-250% increase in torque capacity. This unit reduces unwanted heat and increases holding capacity. Rated at 450+hp on a LT-1 - some chatter - slight increase in pedal effort - and rated up to 550 torque lbs
ціна в Україні - 690$
Part # - EZ3-82040
Алюмінієвий облекшений маховик FIDANZA
1993 - 1997 Chevrolet Camaro Z28 / SS (LT1, 5.7L 350")
Fidanza Aluminum Flywheels are made using the highest quality, most modern materials available. The flywheel itself is made from 6061 T6 billet aluminum. It is CNC machined at a constant surface speed for durability and finish. The friction surface is very special. Fidanza uses 1050 high carbon, alloy steel. It is incredibly durable allowing the user to use just about any clutch disc material available from organic to Kevlar and even sintered iron. The friction plate can be machined or replaced as needed. The plates are secured with 16-20 hardened aircraft quality screws with self locking nuts which prevents any warping. Fidanza uses hardened ring gears that are swarted to the flywheel, with button head screws that are counter board between the flywheel and ring gear to prevent any possible slippage. The mass at the center of the flywheel is retained for strength, but the mass at the outside is eliminated for optimum performance.
Ultra Light and Weighs only 7,5 kg!
SFi 1.1 Approved 2 Part Design with replaceable clutch contact plate delivers the highest quality and longest service life of any flywheel available.
ціна в Україні - 675$
Тепер найскладніше.
КПП.
Багато є різних виробників КПП на цей автомобіль, але найбільш надійною та продуктивною вважають компанію "TCI"
Пропоную розглянути два варіанти:
Варінат 1:
<b>TCI StreetFighter® Transmissions</b>
Part # - 371040
Capability - 450 HP.
Fits 1994 LT1 Camaro. Retrofits will require a control computer such as the TCI® TCU
The TCI® StreetFighter® transmission is tough enough to withstand the rigors of even the toughest street machines. It is ideal for vehicles powered by engines producing 450 horsepower with a non-supercharged system using pump gasoline. Equipped with our 100% tested, Manual/Automatic valve body, most units allow you to manually shift the vehicle into each gear change or, by placing it in the drive position, remain fully automatic. In either mode, you get a racetrack shift that bangs through the gears and shaves time off your ET's. When you use the manual gear selection feature, the StreetFighter® upshifts and downshifts right when you move the lever, with no lag or governor override. When you select the normal drive position, the transmission retains positive, automatic shifts for the ease of driving you look for in an automatic transmission.
ціна такої КПП з доставкою в Україну - 5027,26 $
гарантія підтримується 1 рік без обмеження пробігу
Варіант 2:
<b>TCI Super StreetFighter™ Transmissions</b>
Part # - 371140
Capability - 600 HP.
The TCI® Super StreetFighter™ transmission bridges the gap between our StreetFighter® series and our full Competition series transmissions. It is intended for normally aspirated vehicles powered by engines producing up to 600 horsepower. Like our StreetFighter® units, these are equipped with our 100% tested, Manual/Automatic valve body. That means that most units allow you to manually shift the vehicle into each gear change or, by placing it in the drive position, remain fully automatic. In either mode, you get a racetrack shift that bangs through the gears and shaves time off your ET's. When you use the manual gear selection feature, the Super StreetFighter™ upshifts and downshifts right when you move the lever, with no lag or governor override. When you select the normal drive position, the transmission retains positive, automatic shifts for the ease of driving you look for in an automatic transmission.
Typical TCI® Super StreetFighter™ transmission features are Alto Red Eagle® clutches, Kolene® treated steel plates, Red Eagle®-lined, extra-wide Powerbands™, larger diameter servo assemblies, an improved lubrication system, new sprags/roller clutches (upgraded in certain models), enhanced hard parts where applicable, chrome-plated, TCI®-logo transmission pan, increased thrust capacity, higher line pressure for extra firm shifts & greater torque capacity with less slippage, as well as being TCI® factory blueprinted, inspected and dyno tested.
Built ultra tough with our heavy-duty input drum, heat treated input shaft, extra thick sun shell, super 2-4 servo assembly, extra-wide Alto Red Eagle® 2-4 band, Red Eagle® clutches and Kolene® steels.
ціна такої КПП з доставкою в Україну - 6916,82 $
для будь якої з цих КПП обов'язково потрібно придбати комп'ютер, котрий управляє і контролює КПП. З станадртним комп'ютером вона працювати не буде.
4L60E/4L80E TCU ONLY - 12/5V Square Wave
TCU SYSTEMS INCLUDE:
Transmission Controller Unit in shock-resistant and waterproof case
Complete wiring harness with labeled connectors
T-Com™ WP PC software, instructions and 5 ft. communication cable for TCU to laptop
PART #377010
ціна в Україні - 757,90 $
+ Я би порадив купити до КПП - фірмовий короткоходний шифтер
TCI SHFTR 4L60E 15" 6 BLT TAILSHFT
PART #619025
ціна в Україні - 370,00 $
КПП.
Варінат 1:
Part # - 371040
Варіант 2:
Part # - 371140
PART #377010
PART #619025
- che_guevara
- маскл дядя
- З нами з: 07 травня 2007, 16:00
Re: CHEVROLET Camaro Z28
Когда поменяют коробку и сцепу с маховиком тогда и будут фотоAndre писав: Будемо встановлювати - будуть фото.
Уже сам не дождусь, когда буду ездить.
Кстати, Кравченко мост уже привез. Скоро в єтой машине ничего родного не останется, кроме двига и кузова
CAMARO Z28
Серёжа, рад приветсвовать Тебя на нашем форуме.Сне писав:Когда поменяют коробку и сцепу с маховиком тогда и будут фотоAndre писав: Будемо встановлювати - будуть фото.
На счёт родных запчастей на Камаре - согласен и потдерживаю.
Но не забывай про
BBK LS1 SS1 Intake Manifold Camaro Firebird Corvette TB
Super Sport
Цена в Украине 876 $
А вот что он даёт:
BBK LS1/LS6 Intake Manifold
Intake Manifold, SSI, Aluminum, Titanium Powdercoated, Multi-Port, Chevy/ Pontiac, 5.7L, Each
If you're looking for fuel injected intake manifold performance, look no further than BBK. These SSI performance intake manifolds are high flowing, horsepower adding work hounds designed to provide maximum performance! They're available for a variety of applications to give your street rod the flow it needs and the performance it craves
• Adds 12-25 horsepower over the factory manifold
• Standard 85mm throttle body opening
• Flows approximately 15% better than Z06 manifold
• Made from lightweight 356 aluminum
• Factory style o-ring gasket design
• Standard titanium powder coat finish
Engine Block Style: Stock/OEM standard deck
Injection Style: Multi-port
Basic Operating RPM Range: 1,000-5,800 RPM
Intake Section Included: Complete
Runners Included: Yes
Runners Removable: No
Plenum Material: Aluminum
Plenum Finish: Light titanium powdercoated
Base Material: Aluminum
Base Finish: Natural
А вот Тебе кит впускного тракта K&N
Все патрубки алюминиевіе + хомуті + силикон + пропитка и промывка K&N
Chevy Camaro Z28 with 5.7L LT1 V8 engine
Цена кита для Тебя - 189 $ тут
Вот что пишут сволочи
The Kit comes with:
- 3 inches diameter, heat resistant polished chrome finished air intake tube.
- Hardware parts include clamps, bracket and sleeves rubber (some kits).
- K&N Brand Name Reusable and washable performance air filter (Red Color)
- This is a well known world wide brand name filter that has good reputation.
- By the severity of driving condition the filter suppose to last for at least 50,000 miles between washing.
- It is design for more filtration and strength....etc.
- Installation instruction and customer services.
А по поводу КПП и сцепы - мы готовы
Мы просто сначала искали сцепу и маховик. А уже потом нашли вот эти КПП. механика с возможностью перехода в режим драйв (автоматического переключения передач) ну типа Стептроник. Вот и всёlamak писав:просветитие меня пожалуста нах на автомат коробку маховик алюминевий, сцепа 6 люпистковая??????????
